[FOR SALE] Center Line’s 15x7 Small Bolt Pattern 5x4" Autodrag
4mulas
Fixem'up
Pacific Northwest
Rating - 0%
0   0   0
4 polished Centerline Autodrag wheels. Very good condition.
15x7" with 3 3/8" backspacing. 5x4" bolt circle.
Each wheel needs a minor clean and polish. Will come out like a mirror. Never had weights on the outer lip, only ever one set of tires were mounted on them. Factory silicone seal is like new, no leaks. Has 4 Center caps included which are in fair condition, new ones are still available. Will include 20 New lug nuts as well.
Shipping likely around $160-180 depending where you are located.
Located in Alberta Canada
Payment to be PayPal friends and family only, or cash on pick up if you are local to me.
$1000 obo.
Do they have the bead lock?
Can't tell from your photos.
Back in the day they were off highway only. Then they added the bead lock - a raised bead around the rim behind where the tire bead sits both front and back.
