ceramic coating care
jimjimjimmy
lobsterman
p. e. i.
it seems the ceramic coating on my tti headers is bleeding rust i just noticed this tonite while taking a few pics any ideas on how to prevent this. could i spray rust check on them when the car sits a while. would it stain the header when started? or is there any other products out there that could prevent this and what could i use to get this tarnish off? i bet there is a lot of smart detail buffs out there that have this figured out thanks all
I use Mother's Mag Wheel polish on my TTI's. Works well. I also used Wenol. Don't know if it'll take it all off. TTI recommends that you lay a vapor barrier (plastic) on the garage floor during the winter (cold) season to prevent moisture attacking the ceramic coating. I've been doing this since I installed them, 6 years) and no rust, like yours, is present. Good luck getting it off?
