I am looking to install a Champion CC526 22" radiator into a 70 Duster. I plan to use a clutch fan and I would like to know if anyone else runs this setup and if there is enough clearance between the clutch and the radiator. I understand that the factory shroud should fit just fine.
I've read plenty about the problems that can arise with these rads. Twisted, poor welds etc.
Thanks
Thanks
