Change 8.25 rear axle to big bolt pattern
Early A-Body Discussions
  1. briwill70
    briwill70 Well-Known Member
    120
    40
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:30 PM
    I've got a 65 Dart that has a post '73 7.25 rear end. I found a 8.25 rear axle from a 72 scamp that has a better rear gear ratio. How hard is it to convert that to the big bolt pattern? Is it hard to find axles?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    12,188
    3650
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    2:30 AM
    The 8.25 should already have the big bolt pattern axles
    • Agree Agree x 6
    • SGBARRACUDA
      SGBARRACUDA ROY FABO Gold Member
      19,545
      7953
      Dec 7, 2006
      PLANT CITY FL. and PERRY GA.
      Local Time:
      2:30 AM
      Yes if it is a 8.25, it will be BBP.
    • str12-340
      str12-340 FABO Gold Member FABO Gold Member
      1,770
      1038
      Dec 26, 2012
      Vashon, WA
      Local Time:
      11:30 PM
      No 8.25 rears until 1973. 8.75 in 1972, so this axle (which would be SBP). Now if this is a whole 8 3/4 rear and and you swap it for the 7.25, that would be worth your while... there are several sources for big bolt axles for 8 3/4 rear ends. Would it come with the brakes shock plates, brackets? All different from 7.25 to 8.75, and you would get better rear brakes to boot if you made this swap.
      • Agree Agree x 1
      • McMopar1
        McMopar1 New Member
        1
        0
        Dec 21, 2020
        North Carolina
        Local Time:
        2:30 AM
        What are the sources?
      • 33IMP
        33IMP Well-Known Member
        851
        864
        Jul 3, 2020
        Taxifornia, soon 2b arizona
        Local Time:
        11:30 PM
        An 8 3/4 would be a dropout center section, an 8 1/4 has a bolt-on rear cover. First thing to do is decide what you are looking at. (An a-body 8 3/4 is worth three times what an 8 1/4 is worth).
      • volunteer
        volunteer Well-Known Member
        101
        50
        Jun 20, 2018
        British Columbia
        Local Time:
        11:30 PM
        So what are the primary options to 'upgrade' (8.75) to BBP? I can think of redrilling original flanges or - aftermarket axles. Pros and cons to each of these? Sources or suppliers? Costs? :(
      • 66'GTRob
        66'GTRob Member
        20
        4
        Jun 11, 2012
        Tucson,Az
        Local Time:
        11:30 PM
        I ended up using the Yukon axles for my early A body 8.75 as well as 72 Monaco 11 inch rear backing plates and drums.
        • Like Like x 2
        • str12-340
          1,770
          1038
          Dec 26, 2012
          Vashon, WA
          Local Time:
          11:30 PM
          Yukon are great for a typical high performance street cars. Moser are the best but more expensive. Build for your dream engine if you are going to keep this car around, it's most expensive if you buy them twice...
          • Like Like x 1
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            58,132
            45221
            Jan 18, 2006
            Iowa
            Local Time:
            1:30 AM
            Dr Diff has what you need (after you figure out what you have)
            • Like Like x 1
            • briwill70
              120
              40
              Feb 2, 2020
              Portland, Oregon
              Local Time:
              11:30 PM
              It was a 8.25 with sbp but it sold. The search continues.
            • toolmanmike
              58,132
              45221
              Jan 18, 2006
              Iowa
              Local Time:
              1:30 AM
            • SGBARRACUDA
              19,545
              7953
              Dec 7, 2006
              Local Time:
              2:30 AM
              No such thing as a factory 8 1/4” with SBP.
              • Agree Agree x 4
