Change from 4-speed to 3w/OD
Manual Transmission & Clutch Discussions
  1. Kelster
    Kelster Member
    13
    13
    Dec 9, 2017
    San Antonio
    Local Time:
    10:46 PM
    I have a 63 dart wagon with a 360 and 4 speed trans that I want to change to a 3 speed with OD. I run 70 mph's at 3000 rpm's and I just don't want to ware out my motor. What are your thoughts and where do I look for this transmission?
  2. hemi446
    hemi446 Well-Known Member
    711
    231
    Aug 3, 2013
    Ellicott City MD
    Local Time:
    11:46 PM
    Look for 75-82 maybe pickups or F bodies that is all I know of that came with that overdrive transmission.
    • Like Like x 1
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla
      66,098
      39500
      Jun 7, 2010
      Georgia
      Local Time:
      11:46 PM
      No, you want to change from a four speed to a four speed OD. The Chrysler four speed OD transmissions still carry the A833 designation. That means they are a four speed, not a three speed. If it has four forward gear, it's a four speed. I never understood why people incorrectly call them 3 speed over drives. There were three speed over drives made, with ONLY three forward gears and high was OD. But the A833 tranmissions are ALL four speeds.
      You will need a different bellhousing or you can have yours possibly machined to fit the larger 5.125"bearing retainer in the OD transmission.
      • Agree Agree x 4
      • Disagree Disagree x 1
      • dodge71demon
        dodge71demon Well-Known Member
        3,393
        542
        Apr 29, 2009
        Indiana
        Local Time:
        11:46 PM
        If you do this you will notice a big change in your car and not for the better very low 1st meaning shifting soon but need to build rpm's for the big drop into 2nd third is 1-1 then the OD stay with the 4 speed and slow down what rear gears do you have -- maybe change them to a high 2's or low 3's
      • dodge71demon
        3,393
        542
        Apr 29, 2009
        Indiana
        Local Time:
        11:46 PM
        From Allpar
        Chrysler described the change as “an A-833 four-speed transmission, converted over to a three speed manual transmission with an overdrive gear ratio.” It was used with both the 318 V8 and 225 slant six. After the 1975 run, Chrysler switched to a finer-pitched gear tooth design to reduce the noise of the 1975 models, and changed the overdrive from 0.73:1 to 0.71:1. It used a steel housing except on the Feather Duster and Dart Lite, where it had an aluminum case and extension housing.
        • Agree Agree x 1
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          11,003
          5477
          Nov 28, 2008
          NorCal
          Local Time:
          8:46 PM
          Except, there's all kinds of inaccuracies right in that statement. For example, sometime after '75, maybe '76, ALL of them had aluminum cases. Only the '75 A body 833OD's were all iron case, and at some point they switched to aluminum main cases with iron extension housings, then all aluminum. There are tons of later truck 833OD's with the long b/e style extension housing that are all aluminum. The gear ratio change wasn't by year per say either, it was by application. Trucks got the .71 overdrive, cars kept the .73 overdrive. They kept the 833OD around longer for trucks, so again at some point all the 833OD's transitioned to the .71 overdrive, but it wasn't right after '75.
          Allpar is nice, but it's not a "written in stone", 100% accurate source for everything.
          Better info on the 833's and 833OD's here 4 Speed Transmissions transmission
          As far as what to call it, do you call 5 speed transmissions 4 speeds with overdrive? How about a 6 speed like the T56? Is that a 4 speed with dual overdrive? Nope.
          • Agree Agree x 4
          • Chained_360
            Chained_360 Delusional Member
            498
            238
            Nov 11, 2015
            Indianapolis, IN
            Local Time:
            11:46 PM
            I call my A833OD a three speed with an overdrive because only the first three gears are useful for going fast. If you try to put 300 lb-ft of torque through the overdrive gear, you're probably gonna strip all the teeth off of it. Therefore, it has three speeds for full throttle, and one speed for cruising. Just my 2 cents, because you are technically correct.
            • Agree Agree x 1
            • ConValiant64
              ConValiant64 Well-Known Member
              247
              44
              Jun 26, 2017
              Brigantine, NJ
              Local Time:
              11:46 PM
              I have to respectfully disagree with RustyRatRod. I agree that forward gears should be counted, but only until you get to a 1:1 gear ratio which, in the case of the A833 OD tranny, is 3rd gear. '4th' gear is an overdrive ratio, thus, it truly is a 3-speed overdrive. Hate how tight 1st gear is to 2nd. It's like the Power Glide of manual transmissions.
              • Agree Agree x 1
              • 72bluNblu
                11,003
                5477
                Nov 28, 2008
                NorCal
                Local Time:
                8:46 PM
                So, like I said above, a T56 is a 4 speed with dual overdrive then?
                No, it's a 6 speed.
                And actually, in the 833OD the gear that's the OD gear is actually 3rd gear in the box. It's 4th that's still 1:1. That's why the shift lever is flipped on the 833OD boxes.
                • Like Like x 1
                • Chained_360
                  498
                  238
                  Nov 11, 2015
                  Indianapolis, IN
                  Local Time:
                  11:46 PM
                  Again, you are technically correct. But a T56 won't grenade itself at WOT in 6th gear.
                • ConValiant64
                  247
                  44
                  Jun 26, 2017
                  Brigantine, NJ
                  Local Time:
                  11:46 PM
                  My bad-meant 3rd gear.
                • 72bluNblu
                  11,003
                  5477
                  Nov 28, 2008
                  NorCal
                  Local Time:
                  8:46 PM
                  Only a matter of horsepower, you can grenade anything with enough juice. Put 1,000 hp in front of it and you can lunch a T56 too. Still a 6 speed, just like the 833OD is still a 4 speed. Has no effect on what you call it.
                  • Agree Agree x 1
                  • ConValiant64
                    247
                    44
                    Jun 26, 2017
                    Brigantine, NJ
                    Local Time:
                    11:46 PM
                    Makes sense to me. Let's call it what it is, people!
                  • TF360
                    TF360 Well-Known Member
                    1,765
                    553
                    Apr 25, 2014
                    Florida
                    Local Time:
                    11:46 PM
                    Why don't you change your rear end gear ratio. I had a 360 Duster one time and I pulled the 8 1/4 rear end (3.23's) and put in a junk yard 8 1/4 with 2.43's. I cruised that 360 45 miles to work on the highway for a while.
                  • 72bluNblu
                    11,003
                    5477
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    8:46 PM
                    That's fine for an engine with a small cam and an auto. If you don't make any power below 3k and have a 4 speed, you can't just toss in a set of 2.43's unless you like burning clutch.
                    • Like Like x 1
                    • Marcohotrod
                      Marcohotrod Well-Known Member
                      2,423
                      626
                      Mar 21, 2015
                      Massachusetts
                      Local Time:
                      11:46 PM
                      Kelster-what is your rear gear and tire size? 3000 at 70 is no big deal. change oil + filter more. go to a taller rear tire. the 1:1 gear in an overdrive, call it whatever is strong-the same as all a833 units-I ran 12s with around 450 torque, and the overdrive gear is strong too. call it a 4 gear. my buddy, seaweed the junkmaster , sold me this unit cheap, all aluminum with an iron sidecover and iron front bearing retainer, we turned down the front bearing retainer to 4.80", easier than enlarging the bellhouse (if u have a 4.35" house-not so) and 27 spline output, 308 front bearing, and I banged on it for a few years no problems DSCF0250.JPG
                      • Like Like x 2
                      • Agree Agree x 1
                      • dirty white boy
                        dirty white boy 47 yr old Juvenal delinquent
                        1,284
                        665
                        Dec 15, 2012
                        stoneville n.c.
                        Local Time:
                        10:46 PM
                        this!! AJ be by later and brake down the math on the rato's, he good at it!! its a great idea for your delima in theory but the rato's dont work out!
                      • 67Dart273
                        67Dart273 FABO Gold Member FABO Gold Member
                        45,856
                        13590
                        Oct 14, 2010
                        Idaho
                        Local Time:
                        8:46 PM
                        You guys can call an A833 OD a "3 speed" all you want but all you will do is be incorrect an confuse others.
                        WHEN YOU BUY something like A Spicer 5 speed used in heavy trucks, some models of the gearbox are direct 5th and some are overdriven 5th. THEY ARE NOT KNOWN as a "4 speed with overdrive" they are known as a FIVE SPEED.
                        An A833 is a 4 speed, overdriven or direct.
                        • Agree Agree x 2
                        • 67Dart273
                          45,856
                          13590
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          8:46 PM
                          THIS is an example of a 3 speed overdrive. It is a 3 speed gearbox
                          • Like Like x 1
                          • yellow rose
                            yellow rose Overnight Sensation FABO Gold Member
                            25,846
                            21957
                            Jun 19, 2015
                            Under The Gun
                            Local Time:
                            8:46 PM
                            The OD box has the same first gear as the 3.09 box and I use the 3.09 box. I don't understand how the split bothers anyone.
                            BTW, those who say it's a 4 speed overdrive are correct. It has 4 forward gears and it happens that 4th is direct and 3rd is overdriven.
                            4 speed overdrive is what it is.
                            • Like Like x 1
                            • Kelster
                              Kelster Member
                              13
                              13
                              Dec 9, 2017
                              San Antonio
                              Local Time:
                              10:46 PM
                              I'm kinda with you on this.
                            • RustyRatRod
                              66,098
                              39500
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              11:46 PM
                              I aint the least bit interested in what Allpar says. The designation stamp begins "A833XXXX". That's a 4 speed designation. End of story.
                              • Like Like x 1
                              • Kelster
                                Kelster Member
                                13
                                13
                                Dec 9, 2017
                                San Antonio
                                Local Time:
                                10:46 PM
                                Wow! I think I got more than I bargained for. I will copy all this info and share it with my mech. And thanks all of you for your participation
                                Bare with me I'm new at this. I think we should all agree that this is a 4-speed, if you want to say 3-peed plus OD that would be cool by me even if it ain't proper.
                                Rear gears 323, The back tire is much larger not sure the size, the issue is I want to go faster than 70 and I drive this car a lot and the speed limit where I drive 30 to 60 miles a day is 75 and you'll get runned over if your e not doing 80+, and I'd like to get better gas mileage
                                This is what I understand with out knowing all the science: 1st is shorter, second is longer, 4th is 1:1 but is now actually 3rd gear, the old third gear is now flipped around or something and is now the OD, I also understood this trans will bolt right up, shifter is the right place and everything.
                                • Agree Agree x 1
                                • RustyRatRod
                                  66,098
                                  39500
                                  Jun 7, 2010
                                  Georgia
                                  Local Time:
                                  11:46 PM
                                  Post up some pictures of your car. We'd love to see it.
                                  • Agree Agree x 1
                                  • Kelster
                                    Kelster Member
                                    13
                                    13
                                    Dec 9, 2017
                                    San Antonio
                                    Local Time:
                                    10:46 PM
                                    • Like Like x 5
