Here's what I'm seeing.
During the day things look normal, turn signals operate normal.
Pull headlight switch to parking lights. Left turn signal light on all the time. If I turn on the right turn signal, it blinks normally. If I turn on the left the left light is just solid.
Pull the headlight switch all the way out. The headlights are real dim, left turn signal still acting the same. Charging looks OK at idle, but almost pegs to the right at higher rpms
Any ideas where to start??
Thanks,
Scott
Thanks,
Scott
