65barracudadude
Some of you know that I scored an 8 3/4 this weekend from our wonderful member "Argometer". It turned out to be a sure grip. Which I still just cannot believe. Also here are the measurements. Drum to drum[51.2"], perch to perch[44"], center housing to end of yoke[12.35"]. Now, a original A-body 8 3/4 measurements are: Drum to Drum[ 51.4"], perch to perch[43"], center housing to end of yoke[12.35"]. As you can see, I'm just BLOWN AWAY!!!! This means that this rear will not only work without having to narrow it at all, but it is actually narrower that the original A- body 8 3/4. The only thing I'll have to do is move the spring perches in 1/2" on each side, or buy a pair of the offset shackles. WOW!!!! I'm so happy, I just cannot believe it.
