Cheetah scs shifter 727-904. With cable and neutral start switch and trans brake/line lock button. Forward or reverse shift pattern. Tiny bit of wear on the face from normal use . very few passes. Biondo air shifter for reverse pattern (PRN321) as well. (can be removed and run as the factory forward pattern as well) $450US obo located in BC Canada will ship
