[SOLD] CHRYSLER LA 360 5.9 LONG BLOCK ENGINE MOTOR MOPAR
67DodgeDart360
Delaware
Rating - 0%
0   0   0
I had this engine rebuilt last year. It was for my 67 Dodge Dart but I ended up going with the 340 engine. The guy that rebuilt the engine said he remanufacturer everything. The Heads were redone too. The number on the block is 4006830-360-1. If you have any questions or need more pictures just ask.
Do you have a build sheet of what was done?
The head numbers should be stamped down by the valve springs. Like this;
funny to see this on here i should have known, makes sence its on here. Ok well im the guy that bought this yasterday to replace the 360 in my roadrunner that has a rod knock, to buy some time while me 340 stroker is being built. Thanks Dodgedart360, once i get off work today ill be sending you the payment. Thanks again scott.
