my68barracuda
I am wanting to add protection to the battery cables for the rear mounted battery and also to the alternator charge wire.
I think I understand the basic difference between a resettable circuit breaker and a maxi fuse in that on the CB, when tripped, one would simply re set a lever while on a maxi fuse one would change out the blow fuse for a good one.
Can some one that knows explain the more subtle differences. is one better that the other for battery cable or alternator cable protection?
for a circuit breaker I am looking at one like this
Del City Marine Rated Manual Reset, Surface Mount - 3/8" Stud
for maxi fuses
https://www.oreillyauto.com/detail/...littelfuse-200-amp-mega-fuse/meg200bp/5841888
for maxi fuses
