WARLOCKII
I have decided to go with a small block so its time to sell the big blocks. I have 3 383's and some other parts that I would like to sell as a lot and for pick up only. I don't want to separate or ship as the parts are big and heavy.
The engines are basicly long blocks (block,crank,rods,pistons,heads) they will need to be rebuiltand I believe all are standard bore.
1) 383-4-7-6 (date code) steel crank and 516 heads
2) 383-11-19-68 (date code) steel crank and 906 heads
3) 383-8-6-70 (date code) cast crank and 436 heads
I was told the 70 had been rebuilt when I bought it but after taking it apart it looks like a re-ring (ring ridge with cross hatch). The cylinders have pitting from water sitting in them so it will need bored.
I also have:
1- bb 727 (needs rebuilt)
1- bb water pump housing
2- bb timing chain covers
1- bb timing chain and gears
3 sets - bb valve covers
1- 187 oil pan,pick up and windage tray (the pan has some damage and will need to be repaired)
1- 8 1/4 rear 2:45 non-sure grip from a 76 Dart(needs rebuilt)
2- upper control arms,spindles and 9" drums from a 72 Swinger
All glass (no windshield) from a 76 Dart 2 door
I'm asking $500 for all of the above parts or I would trade it all for a new pair of inner fenders for a 72 Dart Swinger
I also have:
