80arrow
Cleaning the garage. All prices include shipping in the lower 48 unless stated other wise.
F1R procharger, 5.40 ratio, never ran since procharger rebuilt it. Comes with oil and quick change hub for pulley. $2400 This is just the blower, no brackets.
Procharger air to air intercooler, 27" wide, 14 1/2" tall, 3" thick, and 3" inlet/outlets. $375
Extreme velocity pro series carb hat. For 4150, has one hole drilled and tapped in it, polished. sold
Prosystem 950 blow thru carb with build sheet. Sold pending payment
Pro series dual needle and seat float bowls $350
12 rib procharger pulley, 4.25 dia. no offset at rear, $30
Magna fuel 750 protuner, used 2 weekends. $400
Magna fuel boost referenced fuel regulator, not sure of the model, # on reg is c-1137, has five -8 ports, one -10 return. $150
8 3" t-bolt clamps, used. $30 for all
1- 4 1/2" x 2' black silicone tube, new. Was 70 plus shipping will sell for $65
procharger cone type air cleaner. 4 1/2 x 5 1/2 x 8 4" inlet $35
K&n cone type air cleaner 4 1/2 x 6 x 16 with 4" inlet kinda beat up $45
Fast dual o2 sensor with rpm module. Not sure if I still have the disc for it. $375
Autometer 3412 0-100 fuel pressure gauge, new never opened the package, 64 at Jegs mine $50
2- Autometer 3404 boost gauges used, no fittings, $50 each
2 Autometer 2 5/8" mounting cups black, sold
March aluminum pulley part # 10252, mopar small block water pump pulley, never installed, Jegs $105, mine $80
Deadenbear electric throttle stop, 4150, $100
Msd 8980, timing control $50
Holley black pump, holley reg, and canister type fuel filter $85
Arc 3100 switch panel, $95
Holley fuel reg, 12-704, used $50
4 Moroso water pump drives, 3 large pulleys, 3 small pulleys, 3 mounting plates, 2 used belts, and 1 new belt $95
I will take Paypal, as a gift, you pay the fees, on most of the stuff. The more expensive stuff I'd like a USPS money order. Pm me here.
