Before you do any blocking, take a razor blade with 3/4" tape on either side.Lightly scrape away the excess clear,the tape will keep you from taking off too much material.......paitence is the key.
Thanks for the tip on the razor blade. I was looking for the tool to purchase to do this but can't find one. This will probably work just as good and it's a lot cheaper.
I use a "nib file". They aren't that expensive.(under twenty bucks)
I do the razor blade thing to once in a while.
I don't get many runs anymore, but I probably just jinxed that!:toothy10:
I don't call them runs, I call them "air flow indicators" LOL!
