Clock That Distributor !
318willrun
Utube channel 318willrun
I'm here
From past discussions, I've made a video to help (hopefully) understand what and how clocking a distributor looks like. If you know, you know. If you don't, then here ya go!
Always teaching. There are a lot of enthusiasts out there that just don't know.
This year, though, I'm planning (I said "planning" lol) on doing more participation, challenges (with myself is fine), and such, other than a bunch of tech tips. Tech tips, explanations with demonstrations take time and aren't as fun. I'd rather make passes at the track LOL.
I will also add that one of the important things about getting your distributor clocked so the rotor is facing #1 cylinder is this usually gives the distributor w/vacuum advance the most sweep for timing. I've had it where a guy needs a few more degrees of timing and the VA is against the intake. Or could be against the firewall, depending. I also like the number one plug wire/rotor to be in that spot because it makes it kosher to "the books and mopar world".
Exactly. I never put number one anywhere but where the book calls for.
The rub is the drive gear just can’t be dropped in and lined up the same way.
I have owned them
Then you know what I'm talking about, it can be a buzz getting no 1 where you want it and the oil pump indexed.
I agree , I'm not looking for any Chevy cars, but I do like the Chevy and GM trucks, might get me a Silverado or Denali.
Right. Because you need all the room for timing adjustment with the vacuum can stickin out.
Just shared this vid to a member on C bodies. Thanks.
