Clutch Fork Spring?
694spd
Upstate NY
I have all of the clutch linkage installed. I'm just wondering if my clutch spring is installed wrong. I have it hooked to the notch in the bell housing and the notch in the clutch fork. The pictures that I seen show the spring parallel to the clutch adjusting rod and not at an angle as mine is.
It just keeps the fork back so the throwout bearing isnt against the pressure plate when its disengaged. Your good.
