My flywheel is clearly marked by the wear pattern the clutch disc left on it. This flywheel is out of an early A body, so the clutch disc is a little over nine inches. Later models will probably be ten and a half inches. Notice the pressure plate is the same size as the disc. Obviously, this clutch is shot and the flywheel will need to be resurfaced. Hope this helps.
