Clutchflight race transmission
duster doug
DUSTER DOUG
Wisconsin
Rating - 0%
0   0   0
For sale vintage clutchflight racing transmission. Long tailshaft this trans.will make a great addition for some ones old race car restoration 750.00 obo. Thanks doug
Look at the pictures of the front, the four bolts are there that go through the bellhousing. I always wanted one of these back in the day. Best of both worlds.
The bellhousing for this trans is missing but any bigblock lakewood housing will work. the clutch components disc,plate are not with this trans.Any aftermarket clutch kit will work just fine.This trans was used with a hemi back in the 70s. Thanks
Are those energized by a P/S pump or did they figure something out off the splines?
The splines fit into the clutch pressure plate when the engine turns over it also turns the front pump to make line pressure.Then you can shift it just like a 727.This was called a poor mans lenco.
