66340SEDAN
FABO Member #3649
My MSD Blaster 2 coil is leaking some oil where the coil wire plugs in, is it going bad? It seems to work fine. I have it mounted at an angle on the intake (see picture), Thanks!
Keith,
Knowing what is do about high voltage as an Radio Engineer, I would change out your coil. The secondary wiring (the one that produces the high voltage) generates a lot of heat. It's the oils job to transfer the heat to the metal shell of the coil case for cooling. The loss of oil from your coil is like the loss of coolant from your radiator, sooner or later it is going to overheat and leave you stranded.
Steve
Keith,
Steve
