Very easy fix........if I remember correctly........buy a used red/orange marker shift indicator for your steering column (call National Moparts in Beaverton, Ontario 1-888-652-7464 they should have a few) which is just held in with a screw in behind the selector letters (P R N D 2 1)............you'll see the threded hole for the screw......use a stubby screwdriver to run in the screw.
