The only reason I went to shady dell was. He had the guides for my batten heads no one else I knew had them at that time. After paying him over 1100 to put guides in I thought I would let him build the motor the heads were going on.
I bought everything new. Crank, Rods , pistons, Cam . Every piece. And delivered them to him. What he didn't know was I stamped my parts and took tracings and pics. A lot of my parts I bought were not in my motor. Major parts were the Crank, Pistons, and Cam, Lifters and norse rockersGone. He also switched my New CSR water pump for a used one.
He charged me to CNC fly cut my pistons. He did them with a nail file and a 1/2 inch drill through my fresh heads. Then he sanded the tops of the pistons to hide the marks. When I saw the short block he told me he told me the sanding was to help atomize the fuel. Rider Engines in Carlise Pa. was part of this scam. Beware of these A$$ holes too.
I wasted a lot of money through him on that motor . This is Shadey dells mpotor in the car . It made it exactly 10 feet before it left loose and that was in reverse. That is a complete aluminum W-2 Batten top end I lost. Sucks They made more torque on the bottom then the Indys on the dyno and the valves were hitting the pistons. Second pic is the motor in it now built by HTA machine.
Block and heads looked like a mirror and still had seep with Cometics. Mr. Gasket tri-metal gaskets Never seeped on my blower motor in my truck.
For a street motor on pump gas I would go with a good Felpro composite gasket. Less chance of seeping into the cylinders when sitting. That could be a disaster and take out a piston if hydraulically locked.
Just some friendly advise . I use metal gaskets with boost or high compression only. And if I do let it sit I tap the starter and baby it around to make sure it didn't seep in the cylinders.
