valiantwagonguy
I have a real sweet Commando V8 motor for sale.Standard bore,10.5 to 1 comp 235 hp from a standard shift 4 speed car so it can be used either with an automatic or a standard 'cause the crank is drilled for the pilot bushing A273 (1965) It's been freshened up with a new timing chain,oil pump,the heads were all taken apart,checked,cleaned ,and new valve seals put on,new freeze out plugs,new rear main oil seal,pan gasket,head gaskets ,and front seal& gasket.painted with Bill Hirsh Chrysler Red engine enamel .Complete from manifold to oil pan . Located in New York on Long Island. $1000 must be picked up.
