[SOLD] Comp 20-233-3 XE hydraulic flat tappet cam and lifters
Jim Ward
Rockford MI
I have a hydraulic flat tappet camshaft and lifters in excellent condition. I have less than 250 miles on this set before I switched heads and to a solid cam/lifter. Lifters were marked when pulled. $200 plus shipping from 49341
That lifter your holding looks like it's cupped inward. Is that an optical illusion? Just asking because others might be seeing the same thing.
The lifters are not cupped they are in excellent shape. The cam and lifters are both from Comp.
No the box is for the set of solid EDM lifters I put in the motor with the solid mechanical cam. That is not the original lifter box for these lifters. These lifters like the ad and title says are hydraulic flat tappet and are broke in to this camshaft.
