Comp 901-16 Valve Springs
392Mopar
Hazlet NJ
Dropped to $45 shipped in continental US
Have a set of new, in the box Comp valve springs part # 901-16. Bought these for an engine project that never happened so I dont need anymore. Pm if interested, I accept Paypal.
Butch
Comp Cams Valve Springs
1.480 OUTER W/DAMPNER
Set of 16
Comp Cams pn: 901-16
Number of Springs Per Valve: Single
Outside Diameter of Outer Spring (in): 1.494 in.
Coil Bind Height (in): 1.100 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 353 lbs./in.
Inside Diameter of Outer Spring (in): 1.080 in.
Valve Spring Style: Ovate wire
Coated: No
Quantity: Sold as a set of 16.
Stupid question but will the fit on my 360 heads with no prob? And will they handle a 555. Solid cam?
Yeah they will fit on 360 heads with no problems. Dont know the answer on the lift though, says coil bind height at 1.100", you'd have to look into that. I know a member has used these with a Lunati Voodoo cam which have alot of lift, but really dont know the answer.
Butch
Can I use these on a roller cam, I need more open pressure but I'm looking at less then .500 on the valve.
The guy that does my heads wants to see 300lbs on the open valve and 100+ closed. The 901's spec is 242 at .400 lift. almost there but maybe not quite. Maybe at .470 and maybe not?? I'm building a 90 360 roller with a mild cam (haven't ordered it yet but know what I want) so I need springs to control the roller lifters to 5500/6000??
