COMP Cams Cam and Lifter Kit
ColeTrickle74
Rating - 0%
0   0   0
Item is brand-new in box, never used, or run. Its for a Chrysler, 273, 318, 340, and 360. The kit includes the cam, timing chain, gear, and lifters. The cam was placed into a block with new cam bearings but it was never run, just lubed up. Lifters, chain, and gear were untouched and still remain in their boxes.
Quick Specs
Hydraulic flat tappet
Duration 294/306
Lift .519/.524
Link for more info:http://www.summitracing.com/parts/CCA-SK20-226-4/
Lists at $250, I'm selling for $200, free shipping to lower 48. I'm located near Chicago. Leave a PM please.
Thanks for looking, pics are below
Does that kit have to have adjustable rockers? The comp cam and lifters i bought had a foot note Must use adjustable rockers.
I wish I knew enough about the numbers to determine if that cam would work in my 273 Commando. The web page says street but I couldn't find anything about street manners, power brakes yers or no, etc...
ops forgot i had this thread going, sorry if i didnt respond.
might as well bump again
$150 plus shipping, or entertain me with an offer. Thanks
last bump for FABO, 100 dollars plus shipping. need this gone gonna have to try eBay after this
I'll take it for $100 + shipping.
I'm gonna guess shipping is about $25. If you can get me box dimensions and weight, I can check about sending a FedEx tag if you can drop it off.
Check on shipping on your end please. Thanks
