dragondan64
Banned
These are brand new in box, I changed rockers and needed ball/ball pushrods and these are ball/cup for adjustable rocker arms here are the specs from Mancini Racing where I bought them.... Asking $80 plus S/H from Grand Junction CO 81507 Competition Cams Magnum Pushrods Pushrods, Magnum, Chromoly, Heat-Treated, 5/16 in. Diameter, 7.342 in. Length, Mopar, Small Block, Set of 16Fits: Chrysler 273-360ci w/Adjustable Rocker ArmsCOMP Cams Magnum pushrods are the perfect complement to your Hot Street, bracket, oval track, or any other high performance engine. These one-piece Magnum pushrods are made of C1020 high-carbon, .080 in. wall chromoly steel and are heat-treated for use with guideplates. They're an affordable way to combat higher spring pressures and the other stresses associated with high performance engines.$114.95COM7692-16
