DEVIOUSDUSTER
Proud Member
For Sale:
Used Comp Cams Magnum Solid Mechanical Flat Tappet Cam + Lifters
RPM Range = 2500-6000Valve Timing = 0.015
Lobe Separation = 110 degrees
Intake Centerline = 106 degrees
Valve Lash = 0.022
Intake/Exhaust
Duration = (282) (282)
Duration @ .050" Lift = (236) (236)
Valve Lift = (0.495) (0.495)
Lobe Lift = (0.331) (0.331)
Cam description/recommendations via Comp Cams website
PayPal Accepted
Shipping from Prior Lake, MN 55372
- Part Number 20-247-4
- Grind # 282S
- Engine family 273-360 (1964-2000)
Valve Lash = 0.022
Intake/Exhaust
- Solid 340-360 Street Machine / Bracket Race with 2500 stall, 9.5:1 to 10.5:1 compression & 3.91 to 4.10 gear with aftermarket manifold and 650-750cfm carb
PayPal Accepted
