[FOR SALE] Competition Cams Hyd Roller Cam
Mopar Mechanical Parts For Sale
Thread Status:
  1. 360PLUS
    360PLUS Well-Known Member
    182
    70
    Apr 22, 2014
    so cal
    Local Time:
    3:49 PM
    Contact Seller
    Camshaft is 23-713-9
    Cam Style: Hydraulic roller tappet
    Basic Operating RPM Range: 2,800-6,400
    Intake Duration at 050 inch Lift: 242
    Exhaust Duration at 050 inch Lift: 248
    Duration at 050 inch Lift: 242 int./248 exh.
    Advertised Intake Duration: 292
    Advertised Exhaust Duration: 300
    Advertised Duration: 292 int./300 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.549 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.544 in.
    Valve Lift with Factory Rocker Arm Ratio: 0.549 int./0.544 exh.
    Lobe Separation (degrees): 110
    Camshaft Gear Attachment: 3-bolt
    Computer-Controlled Compatible: No
    Grind Number: XR292HR-10
    Valve Springs Required: Yes]
    This set up only has 6 hours run time and 70 street miles
    located So California, 93536 happy to provide more pictures
    $300 shipped please pm
    • Like Like x 1
    • 67charger383
      67charger383 Well-Known Member
      60
      16
      Feb 26, 2020
      Maryland
      Local Time:
      6:49 PM
      Could it be run with 12-1 dome pistons and 915 heads on a 383 with E85?
    • 360PLUS
      182
      70
      Apr 22, 2014
      so cal
      Local Time:
      3:49 PM
      Sure ......providing you have adequate piston to valve clearance.
    Thread Status:
