340plot
the bushy bush
ok, i bought this to use in a project, but am going to twist up my plans.
this is a drop in ready to go 69 340 and FULL four speed setup, minus the hump.
the engine is complete from the intake to oilpan. i have a 750 carb, but needs to be rebuilt.
it has a holley strip dominator intake, m.p 1.5 roller rockers, new timing chain,bearings,rings,oilpump, . heads have been redone with 202 valves(j-heads). it is standard bore block. i do not know exact size, but am told it is 3 steps over stock, and is a solid lift. rods and mains are also standard bore.
the trans is in perfect working condition. comes with, everything minus the hump. i have the tab that mounts to frame for z-bar, z-bar, linkages, shifter, pedals, nuts,bolts,washers.
again, this setup is bolt in, and run.
located 30 minutes from martinsville international speedway in va
4,000.00. cannot duplicate for this cost. it may be steep to some, so if you have no intrest, please move on.
