Sedanman
67-9 Valiant specialist
I was saving this but decided to let it go to someone who will actually put it to use since I don't have a car yet to install it in.
It is a date code 2-10-72 block std bore with 4 valve notched forged pistons
587 J heads 1.88's I think
38744115 distributor
Thermoquad carb 6-2146 needs a soak
228 pan with windage tray
Intake 3671918ae with spacer
I have all bolts,alt brackets & etc for it except for the pulleys & linkage. The bottom end is still complete & not froze & the heads are still assembled. It will need a minor rebuild,bearings,rings,hot tank & go through the heads but it's all there & and an easy build. $800 obo & pick up in chicago
