[FOR SALE] Complete disc brake combo from 74 Plymouth Valiant
bc340
Member
Rocky Top, Tennessee
Rating - 0%
0   0   0
Hi.
Up for sale is a complete set (almost need new lower ball joints) disc brake kit.
Included two spindles with bearings, nuts, washers, locks and dust caps, two rotors, two calipers with hardware, two caliper holders, two dust shields and two upper control arms attached.
NO PADS OR HOSES.
This set will change any of the A Bodies with the small 5 on 4" bolt pattern drum brakes to disc brakes with the 5 on 4 1/2" bolt pattern. You will need a new lower ball joint for a 74 Valiant.
It will also change the B & E Bodied drum brake cars to disc brakes but you do not need the upper control arms.
All parts were in good working order when removed from the donor car. If you purchase these, please look over the parts as its you and yours butt in the car that has to stop. I did not include the pads as they were worn past 60 percent and the hoses as these are cheap enough to buy, you shouldn't use old hoses.
These parts are very heavy. Shipping is possible but local pick up would be better.
$300.00 not really interested in trading.
Thanks,
David
