[SOLD] Complete factory SBP Kelsey Hayes disc brake setup
Azle, Tx
Rating - 0%
0   0   0
Less than 100 miles on this setup since it was rebuilt. Was pulled off to install a BBP Willwood setup. Came off of a 67 Barracuda Formula S. Everything is either new or rebuilt, bearings, seals, hoses, etc. Both hubs have right hand thread studs. Comes with factory balljoint bolts so just drill your drum balljoint mount holes out to 9/16 and this is a direct bolt on. Only thing missing from these are the spindle nuts, washers, and keepers because those were needed to carry over to the Willwood setup. You should be able to reuse your old spindle nuts, keepers, washers. Asking $900 can do local pickup in Azle, Tx or will ship on your dime.
