gdizzle
Ok so I swapped into the HEI for my 1966 dart, 225ci, Slant 6. I now have all of these parts that I will never use. I would like to get rid of all of it at the same time, though I could separate if needed.
What I have: Cardone Points Distributor #30-3610 I bought at AutoZone in Sept. 2015 for $73. It has a lifetime warranty. Though doubt it transfers to 2nd owner.
BWD RU19 Ballast Resistor, bought Sept. 2016 for $7.69.
Standard Motor Products Voltage Regulator VR128, I bought on Amazon in Nov. 2016 for $60. And I have the Standard UC12 Ignition coil, age unknown.
Everything was working fine. I put about 1500 miles on the new distributor.
There is a condensor of some sort attached to the Coil ground. Also you get the coil mount as well.
Also including the Spark plug wire (Denso) that goes from coil to distributor, about 1 year old.
I would be elated if I could get $75 for everything Shipped to your door.
