I'm going to run a compression test on my 340 this week, Assuming that the short block is still stock (72 low compression 8.5:1 pistons and stock 340 cam) What kind of numbers should I have ?
with engine warm -wide open throttle -4-5 revolutions of the motor comp should show
125-145- with no more than 20 -25 pounds variation between cylinders
when i ran one on my 173k 318 in my 71 dart i was pullin 135-150 on all. and mine smokes at times! so if yours has been kept up it should be around there... mine hasn't been..... i have not been nice to my 71...:burnout:
