compressor
70dusta
franklin, MA
hey everyone im gettin ready to get my duster into primer im going to be using the eastwood hvlp gun and it says it requires 13cfm at 30 psi ive got a very small comperssor and i dont think it will be able to handle that at all could anyone recomend to me a cheap way to go for an air compressor thanks
While you are considering your options for a compressor, be SURE you get a good drier/filter for your compressed air line. The system I used did not have a good one and I'm convinced that is why I had to strip all my primer back off to bare metal... surface rust was beginning to bubble up from underneath in spots. I believe it was spitting out moisture with the primer onto the bare metal.
Jerry
