Computer help needed - can't access webpage
grimreaper
Cross Member
Gillette, WY
Can anyone give me some ideas? My computer at home will not connect to the Forabodiesonly page with Internet Explorer, Firefox or Google Chrome. It hooks to evry other webage I try just fine but I get a message that the browser cannot find the page for FABO. I have been having to use my work computer to hook up. Suggestions for how to fix?
Thanks!
Firefox varies with the version, but Google on how to clear the cache, cookies, history for your version.
If you are trying to access it from a saved bookmark/ favorites, instead get on google and just type "a bodies."
maybe your significate other thinks your spending too much time here so they blocked it through your router.
Flush your DNS
For windows
Open the Start menu.
2. Go to Run. ◦ If you do not see the Run command in Vista, search for "run" in the Search bar.
3. In the Run text box, type: ipconfig /flushdns
4. Press Enter or Return, and your cache will be flushed.
Thanks Joey.
I'm working on three computers and doing FABO at the same time and didn't want to have to type all that. :D
In Vista and 7 you can ctrl, alt, del and select task manager.
Then new task, then type "cmd" without the quotes and that will bring up the box to type Joey's instructions into.
Be sure to hit "Enter" after entring the command to flush the DNS cache.
Flush your DNS
For windows
It gave me a message of: the requested operation requires elevation when I tried ipconfig/flushdns
I searched for "clean cache" on google and it said I could run disc cleanup so i did. I now have FABO back.
Thank you!
To log into it as an administrator.
Right click the program for the command box, then select "run as administrator.
Then it would do it,
But hey, if clearing your internet cache did it then cool.
Thank you!
Ya, I'm hooked back up with FABO but I appreciate the help and will remember your instructions in case something like this happens again.
Thank you!
