Connecting electric motor on washer bottle
Monaro
Australia
Going from foot pump to electric motor on washer bottle. Just removed wiper switch from dash, it has 6 pins on back of which 5 are wired up. I was informed that the pin shouild be marked with a 'W' for it to be a electric motor connection (can't find a 'W' on the spare pin) would this be the right awitch to connect up to run motor?
Almost certainly, but check it out. If that "extra" terminal has continuity with any other single terminal when you press the wiper switch shaft, that's the one.
I use the push to washer switch wire to get a single sweep intermittent wipe function.
I have the foot pump wash set up but never installed it.
