airkiller
MOPARS Rule
I am building up a 318 for a 73 Dart for my kid. I have noticed that the clevite bearings I have for the rods present an issue as compared to the shop manual. The shop manual indicates that the rod bearing cap has a "V" Groove in one end of the mating face. The bearing must be installed with the "V" in it lined up with that of the cap. This is to provide oil lubrication in the cylinder bore aross from it. QUESTION: What is done when the Clevite Rod Bearing I was supplied with do not have said "V" cut in them. Are they filed in by the assembler or is there a problem with the bearing?
