JGC403
I was going to put the connecting rods and pistons together today. But I ran into a problem. The rods that I am using have the bearing offset to one side of the rod or a large chamfer. If I remember correctly that is to clear aftermarket crankshafts with larger than stock fillets. So the sides of the rod with the small chamfer go toward the other connecting rod and the side with the large chamfer go toward the crankshaft.
