63dartman
I am starting my first rebuild on a 79 360....I want to keep the cost down so I am having the block and crank reconditioned at my local machine shop. My question is, Do I need to have anything done to the rods before the rebuild? the engine hand turns with no issues that I can see. Also checked the rod side clearance before tearing it down and it was good. I really don't know much about rebuilding so I am probably going to be putting in overtime on the forum......engine is going to be running the kb373 pistons, semi mild cam for street manners and stock 915 heads with headers, 3.23 gears. Hope you guys can help. Don't want to tear it back down because I missed something. Thanks again.
