Thanks for all info and links, I have new brass coming tomorrow, I'm going to stick to stock configuration for now, I picked up a complete, perfect condition engine harness on ebay, no burns, or meltdown. went through it and rewrapped it up. Also got a old firewall connector for the dash side, In perfect condition...so some cars dont seem to have a problem unless the wiring is shorted or additional substantial loads are installed. I found the culprit on my 67, was in the headlight wiring where it came down the kick panel to the dmmer switch, a small short that snowballed into a meltdown. one wire throughout harness had burned into several others bypassing the fuses. The car still ran however and I drove it 4 hours to get it home when i purchased it. I will give this a try just to get it back on the road and start building my new harness with aircraft type wire and connectors I can scrounge from from work. we generate plenty of scrap. I like the diode idea, will implement something like that once I build my harness with a brain box and upgraded fuse center. great links and info on here. Thanks again everyone.
