Considering a Torqstorm for my 225/6
Slant 6 Engines
  1. Exjouster
    Exjouster Well-Known Member
    84
    27
    Sep 29, 2016
    Valrico, FL
    Local Time:
    12:07 PM
    Hey all, thinking about adding a Torqstorm blower to my 225/6 in my '67 Barracuda convertible. Current setup is a Clifford 6=8 package (cam, headers, 4 bbl intake) with an edelbrock 500. Wondering about a few things:
    1. Do I have to pull the engine to get the Torqstorm on?
    2. Would I have to do any modifications to it internally to handle it?
    3. Would I have to do any modifications to the engine bay to fit it?
    4. Would I be able to keep the power steering?
    5. Would those who have used this setup recommend it? Ie, is it really worth the 3k?
    6. Is it something that a novice can bolt-on, or would it require serious skill?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,323
    2971
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    12:07 PM
    I would contact Torqstrom. They shiuld be able to answer some of your questions
    • Like Like x 1
    • Agree Agree x 1
    • goldbike
      goldbike Member
      24
      17
      Jan 19, 2012
      laurens, sc
      Local Time:
      12:07 PM
      I have one on my 63 Valiant, installed it 12/1/2018. I will tell you the way I have mine set-up.
      1. You do not have to pull the engine.
      2. You do not have to do any internal engine mods. I did use an unmilled head and did not deck the block. Used head studs, main studs and rod bolts from ARP. with a fel-pro head gsk. (blew a stock steel gsk. once) I run a comp cams 252 duration 430" lift cam degree at their spec. I run it to 5K. Use a stock exhaust manifolt with offenhauser intake, and running a C&S Specialties blow through carb 550 4bbl. You will be fine with the edelbrock 500 just do the Doug Dutra mod he does in the back of the slant six hop-up manual. I run a push through electric fan on the front as the blower pulley is so close to radiator.
      3. Had to drill a couple of holes on the fenderwell for the adjustable fuel pressure regulator, you will have to run a return to the back of the fuel tank. Also had to oblong the engine mount holes so the engine would sit down in the engine bay a little lower because the top of the hat on the carb would touch the bottom of the hood.
      4. I believe you can.
      5. would cost a little less than putting in a 360 small block, plus it would be different. however when running more than 12lbs. of vacuum the blow-off valve noise is LOUD going down the road.
      6. Yes a novice can do it. They offer 3 different size blower pulleys I have the smallest which gives the most boost 10-12 lbs. @ 4500-5000 rpm. the largest gives 5lbs of boost.
      These act like a turbo @ about 2200rpm it starts to build a small amount of boost(u will need a boost /vacuum gauge in the vehicle)and builds with rpm. It is fun to drive!
      I have run against a 2017 mustang with an eco boost, a 370Z nissan and a late model camaro with a 350. They have all said the same thing, that the faster the speed the harder I pulled away.
      • Like Like x 5
      • Thanks! Thanks! x 3
      • 65 Cuda 340
        65 Cuda 340 Well-Known Member
        123
        136
        Dec 27, 2019
        Tallahassee Florida
        Local Time:
        12:07 PM
        And here's what it looks like.
        • Like Like x 13
        • Thanks! Thanks! x 1
        • K.O. SWINGER
          K.O. SWINGER Well-Known Member
          1,218
          478
          Nov 18, 2010
          oregon
          Local Time:
          11:07 AM
          Wow super clean and great-looking engine compartment. Do you experience any problems with overheating with that setup
        • 65 Cuda 340
          123
          136
          Dec 27, 2019
          Tallahassee Florida
          Local Time:
          12:07 PM
          Goldbike is at work now. Might be a few hours before he can get back to you.
        • theFightingFew
          theFightingFew Always Learning/1975 Valiant Custom/1974 Valiant FABO Gold Member
          85
          100
          Apr 9, 2020
          Philadelphia, PA
          Local Time:
          12:07 PM
          Fantastic! Is the battery relocated to the trunk? I'd love to do this one day... Is this on a daily driver? I'm curious of any precautions to take if on a daily in terms of cooling and all. If you or anyone else knows. Thanks.
        • goldbike
          goldbike Member
          24
          17
          Jan 19, 2012
          laurens, sc
          Local Time:
          12:07 PM
          if it sits after it has been running, the fuel will boil in the carb. causing hard starting, but going down the road does like stock. I an looking for another hood, so i can put a ramcharger scoop on so I can run a heat insulator under the carb. But right not the blower hat clearence to hood is not enough.
          • Like Like x 2
          • goldbike
            goldbike Member
            24
            17
            Jan 19, 2012
            laurens, sc
            Local Time:
            12:07 PM
            Yes, the battery is in the trunk bolted down right behind the rear seat in the center for better center mass. Supercharger kit is 35lbs. total. Still less than a small block.
            • Like Like x 1
            • goldbike
              goldbike Member
              24
              17
              Jan 19, 2012
              laurens, sc
              Local Time:
              12:07 PM
              It uses a Jaguar 6 drive belt, belt tensioner is spring loaded. Really fun to drive.
              • Like Like x 1
              • dustyaman
                dustyaman Well-Known Member
                107
                31
                Apr 23, 2012
                conway ar
                Local Time:
                11:07 AM
                I’ve been wanting one myself. But money is the issue
              • Charrlie_S
                Charrlie_S Well-Known Member
                2,931
                759
                Oct 17, 2005
                Silver Springs, FL
                Local Time:
                12:07 PM
                "Speed costs money, how fast do you want to spend?"
                • Like Like x 4
                • volaredon
                  volaredon Well-Known Member
                  144
                  17
                  Feb 28, 2010
                  IL
                  Local Time:
                  11:07 AM
                  Been wanting to assemble a low buck junkyard sourced version myself
                • RustyRatRod
                  RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                  61,713
                  33713
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  12:07 PM
                  Put one of these bad boys under it. That'll solve that mess.
                  Holley 108-51: Insulating Carb Gasket Heat Shield Fits Holley Model 4150&#0153 and Model 4160&#0153 Square Flange Carbs | JEGS
                  • Like Like x 1
                  • goldbike
                    goldbike Member
                    24
                    17
                    Jan 19, 2012
                    laurens, sc
                    Local Time:
                    12:07 PM
