Console automatic ????
6pakattack
Rockwell,NC
OK,just got my console shifter mounted in my car ('69 Dart),all I get is PRND2,no 1 !! Are there diferent transmission mounted brackets for the various fitments ??? Rod is adjusted as best as I can get it !
you may have the wrong up down rod going thru the floor.....I mounted one over a 727 in my 66 cuda and could either get 123nr or Prn32....there is an up down rod that has an adjustment on the rod at the bottom where it connects to the forward rod that actuates the trans shifter ....until I installed that rod I missed either park or 1.....
I do have another that I can try, Thanks for the info !!
