Console shifter with 904 linkage to a 727
Jimmy J
New Member
Memphis, TN
Is there a conversion kit so I can use the floor console shifter with the 904 linkage with my existing 727 tranny?
The floor shift linkage is the same between a 904 or 727, except for the torque shaft bracket pictured in black...
I used all of the consol linkage from my slant/904 to a 340/727 Years ago, but I can’t totally remember if it was a direct bolt on or if I had to modify something Kim
I pulled my slant 6 904 and installed a 360 727 and use all of the same brackets and linkage without modifications. Works fine.
