After following along on the earlier posts regarding the fuel sending unit, I decided to replace the one in my 73 Dart Sport. (I also ran out of gas on Saturday for about the 5th time which added incentive)
I have noticed that when the car is full of fuel, it will register about 1/4 full. Once below about 1/2 it does not register.
After testing the gauge with a tester to make sure it was Okay, I pulled the fuel sending unit. (I found that getting it out with the tank installed was space limited) After removing the unit, I tested it with my Multimeter. With the sender wiper in the full position I tested 10 Ohms. Empty it tested between 78 and 89 Ohms. Next I crawled under the car and attached the unit to it's lead and grounded it. With the ignition on, the unit registers full with the wiper arm up, and empty with the arm down. The gauge also followed the wiper in other estimated positions, confirming that it is working normally.
The plastic float has a small amount of trapped fuel, and the wiper moves fairly freely.
My next move will be to reinstall it in the car. However, before I do this (and fuel the thing) are there any suggestions regarding the life of the sending unit, and what else could have been preventing it from working normally in the past?
In other words, is it better to replace it, or keep it and continue to trouble shoot?
