ir3333
How many guys have made this conversion and how do you like it?
I just picked up a 904 with these mods.
It will keep you sane when leaving the intersection, for the street with hwy gears coupled with a slant/2 brl 273 car... it helps for that.Thanks for your input...exactly what i'm planning...2.94 rear gears.
With a lock up 904. Lucky dog! I had a tranny but scrapped it.Using the 2.74 set in my barracuda street car, working well with 2.94 rear gear , turning around 2200 rpm at 65 mph.
not quite its 1st gear only. 2nd and 3rd are the same as any other 904/ that I do know for sureI maybe late but I have the 2:74 gearset in my 904 behind a 340. The rear axle is a 3:55 with 26.5 tall tires.
I really think it helps the car get rolling much quicker. My set came out of a /6 truck trans because they needed as much help as they could get accelerating from a light or pulling a trailer.
In case you didn't know the low gearset is 1st and 2nd gear only. Third gear is still 1:1 so you get a noticeable drop in RPM shifting out of second into third. But if you have a torquey engine it's really not a problem.
