jkeck55
I am considering removing my vinyl roof completely and going without it when I get the body work done. I am wondering what problems I may encounter. I know there are clips to hold the trim on and I would assume removing those will leave holes. Is that the only issue I should expect other than the possibility of rust under the vinyl?
I will be taking the vinyl off to make sure there is no rust so we shall see.
