e50095 Well-Known Member Joined Jan 27, 2010 Messages 216 Reaction score 47 Apr 1, 2021 #1 I know the existing e brake cables work in this upgrade, but do I also use the existing e brake lever and the piece that runs between the shoes just under the wheel cylinder, or are they different for 11" brakes vs 10?
SGBARRACUDA ROY Legendary Member Joined Dec 7, 2006 Messages 22,009 Reaction score 10,662 Location PLANT CITY FL. Apr 1, 2021 #2 You need to use the 11” parts.
64mopar Well-Known Member Joined Apr 14, 2019 Messages 466 Reaction score 627 Location PittsBurgh Apr 1, 2021 #3 You will need everything from the backing plate out for the 11 inch brakes. You can buy the appropriate kits( springs,etc.).
cudamark Well-Known Member Joined Mar 14, 2009 Messages 11,771 Reaction score 3,431 Location San Diego Apr 2, 2021 #4 If you're converting from stock A-body SBP brakes, you're going to need different axle shafts too.
