Jack,
First you will have to make up your mind as if you want to run injected or carburated alcohol as the fuel systems are totally different.
For carb. alcohol you will need a fuel pump that will handel alcohol and a regulator that will flow enough. You will need at least 1/2 line or #8 braided steel. The reg. will have to be set so that under WOT that the pressure won't drop below 8 psi with G force applied. So this is what you'll need
1. A carb that will run Alcohol
2. A fuel pump that will deliver more than needed and is compatiable
3. A fuel line thats large enough to keep volume to the carb under high loads
4. A regulator that will flow enough through it to supply the carb.
5. A large enough tank to get the distance you want to go
Depending on the heads that are used will determine the amount of fuel that will be used over a given time, larger ports req. more fuel and smaller ports req. less fuel. Most of the time Alcohol will use 1 1/2 times the amount of gas, so if you burn 1/2 gal in the 1/4 then you'll burn 3/4 gal of alcohol in the 1/4.
Now for injected Alcohol you'll have to have the tank mounted in the front of the car as the pumps won't and aren't designed to push they are designed to pull fuel. So for mech. inj. the lines are going to have to be larger than that of the carb. type as the pumps require more volume, so this is what you'll need
1. A complete mech. FI system like Enderle or Rons, or Hilborn
2. #12 or #10 line min.
3. Fuel shut off and cables if not with the system
4. Fuel pump if not with the system
5. Your intake machined for FI nozzels
6. 1 or 2 fuel by-passes depending on the system
7. A set of fuel pills to regulate amount of fuel needed to run engine
8. A fuel tank that will accept a fuel return line or lines
9. A belt drive pump setup or the necessary hardware to run a cam drive
10. Plenty of $$$$
A alcohol carb setup will run about $1,000.00 - $1,200.00 with the pump line and regulator, and carb.
A mech FI setup will run depending on the system anywhere from $1,600.00 to $3,000.00 and some are higher than this.
Your engine will need at least 150 psi to run alcohol and no less so 10:1 should be the lowest compression. Then you'll need a Ignition hot enough to burn alcohol the more fuel the hotter the ign. has to be. For a supercharged Alcohol engine we use a Mag 44 from MSD this means that each plug will see 44 amps of juice when fired but we also burn 7-8 gals per run and in 5 seconds. Nitro cars run twin 44's as nitro is harder to light, also with this much amperage the timing has to be reduced to 26 - 28 degrees total or high speed engine dissassembly will occur.
Hope this helps
