Cooling Question
MOPARJ
What can I upgrade now?
Thousand Oaks, Ca
What would the radiator size be for a 73 Duster 318 with a/c. Would it be 22 or 26 inches? Im trying to find fan shrouds for that car and my non a/c 340 in my 69 Barracuda. Would anyone know that size as well?
http://www.mopar1.us/radiator.txt
Looks like it should have a 26" radiator in it.
That pretty much answers that question, Rob. It looks like 26" for the Duster and 22" for the Cuda. Now I just need to figure out if I need to find a 26" rad fan shroud that is particular to 1973 or if a shroud for the same size rad from 1969 will work. Hope so, as I can't find anything that matches a 1973 model year, with the exception of one for a 340, which was $225.
Another quick question: I have Hooker headers on the 318. What would you or are you using for small block headers on the drivers side with the last two spark plugs: straight angle spark plug boots or right angle boots?
I'll walk the boneyard over here and see if i can find a 26" A fan shroud. they had some late A's out there.
Ahh my favorite headers in the world... :sign11:
On the rear two, I put 90* boots on and either run them very tight to the valve cover or point them downish and swing out towards the master cylinder, then across to the distributor.
Yeah, I nabbed two old 90* wires and put them on the rear left plugs and they don't match my other Accel wires, but im thinking about replacing those with all 90* wires anyways. I pulled those two wires up as close as possible to the valve cover, but the damn things started crossfiring on each other, as one had a slit in it. Dammit. So, I had to use two straight angles pulled as tight as possible, but they are still starting to melt.
As for the shrouds, that would be awesome, Rob.
