dibbons
Can someone recommend a source for the correct speedo cable for our '65 Formula S? How long should it be? Thank you.
Yes, I have a couple of complete ones incl the grommet.Di you still have your original cable? If so there’s a place in Texas that can rebuild your cable and looks/works like new
ULF @65dartcharger do you have any spare 65 cables in case the OP can’t find a new or good used cable?
'62-5 A-body are the same....all engines and transmissions. 58 43/64" long.Can someone recommend a source for the correct speedo cable for our '65 Formula S? How long should it be? Thank you.
